It is currently Wed Feb 21, 2018 1:16 pm
Post new topic Reply to topic  [ 275 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19  Next
2015 Club Funder
1,842.05 Points
Post Posted: Wed Aug 31, 2016 12:16 pm
Any takers?
"Be yourself, everyone else is taken"- Oscar Wilde
Post Posted: Wed Aug 31, 2016 7:18 pm
nope. bout to start posting it everywhere though
Post Posted: Sat Jan 28, 2017 8:25 pm
Wow its been a long time. Im starting to get back at it slowly.
Post Posted: Sun Jan 29, 2017 10:43 pm
Sweet! What did you paint the bracket with?
3,405.35 Points
Post Posted: Sun Jan 29, 2017 11:01 pm
I was going to ask the same thing. I have one built out of sst. I have to weld in a few panel. Then paint it.
Post Posted: Mon Jan 30, 2017 10:28 pm
after i stripped it i used alodine to treat the aluminum. then i primed it with an epoxy primer. i ended up painting it with a single stage polyurethane paint.
Post Posted: Fri Feb 17, 2017 9:09 pm
So that fish box looks like hell. i hate it. i cut it out and starting from scratch. i took my fuel tank and popped a mold off of it. this will now be my fishhbox. i still have a little work to do to it but not nearly as much as the last one
Post Posted: Fri Feb 17, 2017 9:11 pm
i found a door for my console. i have to clean up the frame a bit but will work out great. best part is i found it for 20$. im still all over the place but not as bad as the last time. trying to not burn myself out this time
Post Posted: Fri Feb 17, 2017 11:09 pm
Dude, you got Cuban hatches and holes all over that boat sSc_eek And you live in South Florida........... me sCo_hmmthink you can ..... well nevermind... :doh:
:1143_neener_neener_neener:
That is a pretty cool idea on the fuel tank and door. I really like it.
3,405.35 Points
Post Posted: Sun Feb 26, 2017 9:41 pm
Corey I was once told by a very smart guy. When you have a long way to go, don't rush, just take one step at a time. :605_thumbs_up:
Post Posted: Tue Feb 28, 2017 11:35 am
I went and got some core material and started getting things done. and then my back went out on me again. so next update will be a ways down the road. just as i was starting to make headway...
so basically i got the deck cut to fit. then placed my fishbox and hatch gutter. after i did all that i layed a layer of 1708 on the bottom side. flipped it back over and routed out where the gutter sat in the deck. then with thickened resin i glued it in. once that set up i flipped it over and laid a layer of 1708 over the deck and bottom side of the gutter to tie it all in so to speak. while that was still wet i put the fish box on. put some weight on it and put a layer of 1708 on the front and back lip. i still need to add a layer of 1708 over everything on the bottom but the fishbox is secured to the deck
Post Posted: Tue Feb 28, 2017 11:45 am
Looking good Corey!
Post Posted: Wed Mar 01, 2017 12:48 am
:605_thumbs_up:
1,257.50 Points
Post Posted: Mon Mar 06, 2017 11:49 am
:605_thumbs_up:
John L. Dupree III
1999 Aquasport 245 Explorer - 225 Johnson Ocean Pro
AQABLA84E99
Post Posted: Tue Mar 07, 2017 9:28 pm
well i got the bottom of the first panels done. couple layers of 1708, and i added some stiffeners to the center for a little added assurance.
7,791,703 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
