It is currently Fri Feb 23, 2018 12:49 am
Post new topic Reply to topic  [ 120 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
831.05 Points
Post Posted: Wed Dec 02, 2015 10:06 pm
Got another 222 in for a rebuild. She needs everything except maybe the casting deck!
Tried to salvage outside skin but to no-avail..
Got some sweet new 1603 glass. Its real pliable like a straight biaxial and has just enough mat on the back to fill imperfections when lamming onto an old hull surface, and doesn't suck near the resin a 1708 does. Wets out real nice!
Core goes in tomorrow...
Post Posted: Wed Dec 02, 2015 10:17 pm
Nice work as always!
Post Posted: Wed Dec 02, 2015 10:58 pm
Chris when you have to take the transom skin off and with the all that associated effort involved, how much more would it take to add a 2 foot plug to the hull?
Post Posted: Thu Dec 03, 2015 12:40 am
looking good, you have a real talent my friend :605_thumbs_up: thanks for sharing it with us.
831.05 Points
Post Posted: Thu Dec 03, 2015 9:32 am
Thanks guys :1992_beer_cheer:
@Dave, Id imagine probably another day or 2 of fitting more of that dam material to extend straight off the bottom, and running a bunch of battens back off the hullsides and covering with a layer of formica or 2, then cutting transom angle and setting up another vertical dam.
Glassing would be the bitch, id probably do the bottom and sides in one go then the transom skin the next day...
O by the way, I left that 4" lip all around for 1-to help keep shape and 2-so my outside seam is on the flat of the transom and not on the edge where it would be a pain to glass and fair...
Post Posted: Thu Dec 03, 2015 10:20 am
Just wonderin man, the scope of the project is such and the speed that you work it seems to me cats would be smart to ask you to do that for the gain in space... The L&B ratio would change too that I imagine she would drive even easier and be more efficient.. A really big Rescue Minor.....
You're killing it man for sure!!!!!! :605_thumbs_up: :605_thumbs_up:
Post Posted: Thu Dec 03, 2015 1:24 pm
Chris, beautiful work. PM sent, thanks.
Post Posted: Thu Dec 03, 2015 9:27 pm
Dave, r.e. the stretch, some rebuilders in the Tampa area have stretched a 22 to 24...and 240 Seahunters to 26.
Guess the idea is to go for the Gause-Built customer.
831.05 Points
Post Posted: Thu Dec 03, 2015 9:53 pm
I almosttt did it to mine... Im sure ill do one at some point.
I don't think I could do one for the Gause crowd lol. Got more money than sense!
Post Posted: Thu Dec 03, 2015 11:54 pm
Bud, from what I've seen....you can hold you own on any coast.
Interesting though regarding hull extension.
On the left coast there is a ring cap for an extended 22-2 to 24 feet. Also a 240 Ocean Hunter if you'd like to convert to center console.
Last but not least....a ring cap mold for the 240 extending to 26 feet.
Post Posted: Fri Dec 04, 2015 12:55 am
Scotty it would be cool...
The rule from the old boys the likes of George Crouch and Weston Farmer was to try and stick close to an LB ratio of around 5.. Long and narrow, sea kindly and very easily driven and fast with low power. The old 222 hull form would be perfect for that.. You stretch her out long enough and build light she'd run 15 with 50hp... Check out Robb White's variation of Rescue Minor.. When Chris finally builds that I wanna see it!!!!
Post Posted: Fri Dec 04, 2015 4:08 pm
excellent work! im super jealous if you being able to have a covering for your boats.
831.05 Points
Post Posted: Sun Dec 06, 2015 12:38 pm
She'd really look like a banana boat at 25ft haha
I think if you kept the shear sloping back another couple feet youd be too low in the stern. Have to bring it back up I reckon...
831.05 Points
Post Posted: Sun Dec 06, 2015 12:40 pm
O it would be impossible to get anything done without a cover! Eventually I wanna do something more permanent to fit 2 underneath. Need to get that Intrepid out so I can get the 222 under the big top!
Post Posted: Sun Dec 06, 2015 5:07 pm
and this is why i havent touched my boat. city of sunrise doesnt allow tents or temporary carports. but hey at least i can have a boat. keep us updated, you do great work.
7,796,285 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
