It is currently Wed Feb 21, 2018 1:02 pm
Post new topic Reply to topic  [ 5 posts ]
836.55 Points
Post Posted: Mon Jun 27, 2016 6:12 am
I am not sure what to call this thread but from time to time I get water in this spot as I soak it up with rags I see a plug. Can I remove the plug and let it go into the bilge?
I have no leaks on the boat this water is only from splashing and rain.
Post Posted: Mon Jun 27, 2016 12:59 pm
Are you the original owner? I ask since it looks like that hole was plugged after construction. Bruce and Scott (both explorer owners) will happen by shortly. They should be able to help you.. I am an Osprey owner so I cant weigh in on this one.
b
Post Posted: Mon Jun 27, 2016 4:03 pm
Different Explorer model Bruce. The 215 is a completely different animal than the 225/245/250 Series Explorers. The 215 cabin liner extends up under the cockpit floor a few feet. The slide you see is for the porta-potty.
Post Posted: Mon Jun 27, 2016 4:18 pm
OK I talked to my buddy who is a 215 Explorer owner. He said there should be a pvc pipe (about 3/4") in that hole. He said that if there is any water in the bilge and he comes off of a plane quick, the bilge water will rush into the cabin thru that drain hole. So he keeps a rubber plug in that drain to prevent that from happening. That is probably why the PO plugged it up..
Post Posted: Tue Jun 28, 2016 11:15 am
Ahhh.. Makes sense. Would a drain with a right angle solve that problem allowing outward draining while preventing backflow?
7,791,629 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
