It is currently Wed Feb 21, 2018 3:09 am
Post new topic Reply to topic  [ 111 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
Post Posted: Sat Feb 25, 2017 8:00 am
Well i appreciate everyone's help up to this point. But i need to take a couple of weeks off and get to work. I have to be able to pay for this rebuild somehow. I will be seeking guidance once again when i return in a couple of weeks from my trip out to sea. Unfortunately i will not have internet access where i will be.
Time for me to gout on this boat
586
So that i can go and catch a bunch of tasty scallops!!
587
Post Posted: Sun Feb 26, 2017 12:25 am
Have a safe trip, good luck on your catch.
Post Posted: Sun Feb 26, 2017 1:22 pm
Thank you sir! In Cape May, NJ loading 30 tons of ice and then heading out to sea!!!
Post Posted: Sun Feb 26, 2017 1:52 pm
Have a good trip. cape may though.....uhhh
Post Posted: Sun Feb 26, 2017 2:03 pm
Sounds like you don't like cape may....
Post Posted: Mon Feb 27, 2017 8:11 pm
I went to boot camp there, so i have some different memories than most people.
Post Posted: Thu Mar 02, 2017 11:11 am
Ceejkay... Coast guard right? If so then I can understand your feeling towards cape may!! I got boarded by the coast guard 2 days ago. They did a fishing vessel inspection to make sure I was in compliance. Now I am off the beach of Manasquan riding out this storm. Got 35-45 knot winds and 10-15 foot seas rolling in on us. Heading back out this afternoon!
Post Posted: Fri Mar 03, 2017 7:46 pm
Yeah im a coastie. but im an airdale, so if you ever see me its a bad day. Safe travels!
Post Posted: Wed Mar 08, 2017 8:50 pm
Yes if i see you above then it is a BAD day!!! Well i am back got back in today. Have to unload all those thousands of pounds of scallops! Had crappy weather the whole time, but glad to be back and ready to get back on my rebuild!!!
Post Posted: Wed Mar 08, 2017 9:54 pm
welcome back!!
Post Posted: Tue Mar 14, 2017 5:38 pm
Well i tackled the port side stringer this afternoon. Figured this side would be easier than the starboard side right now. I used a multi tool to cut it out. Not a whole lot of dust using this tool and was fairly easy. Now i just have to do some grinding on this side and clean it up and then onto the starboard side. There was a very small small amount of water. Other than that the foam was really dry which is a positive. Hope the starboard side is just as dry!!
596
597
598
Post Posted: Tue Mar 14, 2017 5:40 pm
600
601
On the starboard side i need to cut more of the wiring trough out so i can have more access to the stringer!
602
Post Posted: Wed Mar 15, 2017 7:24 pm
Well i did some grinding where i removed the port side stringer. Let me know if i need to do more grinding or if i need to go back towards the stringer some more. I am so ready to get this transom in and feel like i am making progress. Instead of feeling like i am just taking this old girl apart!!!!
604605606607608609
Post Posted: Fri Mar 17, 2017 9:23 pm
That looks pretty good to me. just make sure it flows so when you glass you dont get any air bubbles.
Post Posted: Sat Mar 18, 2017 3:49 pm
Well I got the starboard side stringer off today. Wasn't to hard to get off. I did have some wet foam at the end towards the transom. Up at the end of my cut was completely dry.
610
611
612
I did some more grinding to get ready for laying up some 1708 on the inside of the outer transom skin. I noticed I kept hitting air pockets as I was grinding. So now what do I do about this? Do I just lay thickened epoxy in the gaps around the wood and lay new glass over it? Or do I need to do something else?
613
614
615
Also if you notice where the hull meets the transom. There is like a notch or valley right by the drain hole. Do I need to grind that out more? Or not worry since thickened epoxy will go in there when I do my filets?
616
617
Also I put my transom template in there. Are the gaps to big around the edges? Or not worry since it will be filled with thickened epoxy with the filets?
618
619
7,790,662 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
