It is currently Fri Feb 23, 2018 10:32 pm
Portal » Board index » Welcome New Members, Please Introduce Yourself Here
65.20 Points
Post Posted: Sun Jan 08, 2017 8:41 am
Hi all. I own a 1982 ccp 222 with a johnson 200. Looking foward to spending some time reading about others boats and picking up tips and tricks. Im a weekend warrior fishing offshore Ft.pierce and St. Lucie inlets. I spend more time in the driveway than offshore but i enjoy repairing/upgrading anything i can. Here are some pics. Btw i would like some info on closing the transom in without having to permanently attach it if its possible. ..just thinking out loud.
Post Posted: Sun Jan 08, 2017 10:18 pm
Boy that is some great access out through the stern!!! Welcome aboard! :605_thumbs_up: :605_thumbs_up:
Post Posted: Sun Jan 08, 2017 11:17 pm
Welcome to the club! cant say ive ever gone out of those inlets. i always went out of jupiter or stuart. in my sig is my 222 with a closed in transom. you can see on the first page of my build how i got the boat. might give you some ideas
Post Posted: Mon Jan 09, 2017 5:30 pm
Welcome aboard!!
You could make a drop-in wave gate using off-white starboard, notch the bottom to go over your rigging tube. Slide it in from the top when you go offshore.
Post Posted: Mon Jan 09, 2017 7:22 pm
Welcome aboard!!
Scotty beat me to it. You can use starboard or make a gate using Coosa, Nida Core. Just make a channel for it to sit in and middle support. Might want to put a beam across your piece to keep it from bowing. That transom bracket will help a lot with keeping water out of the back.
Nice boat
Post Posted: Mon Jan 09, 2017 11:09 pm
Good thinking Kev, the composite will be lighter and stronger than the starboard and after it's glassed can be gelcoated to match. Channels on the verticals and the bottom horizontal and he's set.
7,799,019 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
