It is currently Tue Jan 16, 2018 1:33 pm
Post new topic Reply to topic  [ 3 posts ]
Post Posted: Tue Feb 21, 2017 6:02 pm
Over the years it seem I've accumulated a good number of gauges and it's time to clear this out a bit. Many are free to our Aquasport friends! I will try to take some pics and post them soon:
I've got a bunch of older Teleflex gauges - they all work and actually have working bulbs in them too! These match, come with mounting brackets, and are free - 6000 RPM tach 3 1/2", and the following that are 2 1/8" - fuel/gas level, oil pressure, temp, volts
Medallion 4000 RPM tach - 3 1/2" - free (above)
Nice 2 1/8" VDO gas gauge x 2 - $10 each
Nice 2 1/8" VDO volt meter - $10
Nice 2 1/8" VDO oil temp - $10
Near-new 2 1/8"30 PSI Faria outboard water pressure gauge
Nice AutoMeter quartz analog clock - 2 1/8" - $10
Teleflex International red fuel gauge - nice - $10
Quicksilver blue series that match and are in very nice shape: 6000 RPM tach 3 1/2", and trim/tilt, water pressure, also matching Teleflex blue volts and fuel level - all 2 1/8"
New, still in-box Quicksilver volt gauge x 2 - $20 each
New, still in box Teleflex International blue temp gauge 2 1/8" - $20
Floscan 3 1/2", 32 GPH fuel monitor - very nice - gauge only - you will need the right sender for your setup - make me an offer!
Navman F2100 2 1/8" fuel flow monitor/system - make an offer! I may have the sender for this or you may have to get a sender.
VDO +150 analog amp gauge - uses external shunt that is not included - free!
PM if you have questions or let me know what you want!
1,257.50 Points
Post Posted: Wed Feb 22, 2017 10:23 am
PM sent.
John L. Dupree III
1999 Aquasport 245 Explorer - 225 Johnson Ocean Pro
AQABLA84E99
3,805.55 Points
Images: 45
Post Posted: Mon Feb 27, 2017 8:25 am
PM sent
Dave
88 222 Osprey
00 Yamaha OX66 150
7,677,279 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
