It is currently Thu Jan 18, 2018 11:26 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page 1, 2, 3, 4  Next
Post Posted: Thu Mar 07, 2013 1:13 am
Putting holes in a boat for speakers and where can be a nerve racking job for some, let's post some pics of where ours are mounted to help others down the road.
2013 Club Funder
1,436.90 Points
Images: 20
Post Posted: Thu Mar 07, 2013 2:32 am
I just bought a stereo. This is a great time for this post. Also, where do you guys mount the head units? I've been thinking about mounting mine inside so it can locked in.
Post Posted: Thu Mar 07, 2013 10:15 am
That's not a bad idea but does the head unit have a remote you can mount on the helm?
Post Posted: Thu Mar 07, 2013 2:33 pm
I started with a head unit in here in the grey box
Ended up moving it here, like it much better
Instead of cutting holes int the boat I used the pie plates, stereo and speakers are 5 years old now and still work
2013 Club Funder
1,436.90 Points
Images: 20
Post Posted: Fri Mar 08, 2013 4:26 am
No, there was no remote for that stereo but I'm returning it. I plan to upgrade. I want something that I can mount 6 speakers to so I can also have 2 speakers in the cuddy.
Post Posted: Fri Mar 08, 2013 11:31 am
James, I'm sure you know this, but if not...speakers are the key to the sound of your system. I am a firm believer in Infinity speakers, just got these in this morn for the rear deck of the Maxima...
They will be replacing Infinity Reference series, as the Kappa is the next step up. I have to stay with the specialty size (5 1/4") to keep the install looking totally stock.
What's great about Infinity's (and any good speaker) is there sensitivity, measured in db's. The higher db measure, the more sound you get from the same given power input. Thus, at low levels of power, you get clean, crisp sound without having to crank the volume. That is the number I look at when buying speakers. Now Scott knows the Max is not lacking for power (2000W Pyle 6-channel amp in the trunk!), but I like having the sound I want at low levels of power.
What I recommend is a relatively inexpensive head unit with the best speakers you can afford. With no separate amp, you'll want a head unit with at least 40W X 4 channels. And for 6 speakers (2 bridged), you'll want a head unit with 2 sets of pre-outs...
Post Posted: Fri Mar 08, 2013 11:55 am
heres where i put 6 1/2's on myy 19'6
Post Posted: Fri Mar 08, 2013 1:30 pm
Bob who do you deal with for buying speakers?
Post Posted: Fri Mar 08, 2013 5:15 pm
The head unit in my 245 Explorer is mounted in the cabin on the aft port wall:
Post Posted: Fri Mar 08, 2013 5:30 pm
Scott,
I picked this pair up from an outfit called bargainsunlimited on ebay. Love Infinity's, got them installed this aft and they sound great!! Paid $80 for the pair shipped, and they got here in 3 days. http://www.bargainunlimited.net/servlet/Categories
Don't let the Euro sign full you, they're in Texas...
1,200.95 Points
Post Posted: Mon Mar 11, 2013 4:45 pm
I just put a stereo in my boat. You can find some good deals on Poly Planar stereos if you shop around. I bought a MR41 Cpak which can be found for around $100. bucks. It contains everything you need. Head unit, spray cover, and two marine speakers. You can hook up four speakers to the head unit, and they also have a small separate add on amp for two additional speakers.
There is also good good deals on the separate head/tuner models, but they do not have speakers.
As far as cutting holes in your boat, just use the template and carefully mark the location with a Sharpie. Then drill a starter hole and cut it out with a sabre saw. make sure you have the proper clearance behind the mounting location, and no wires or other cbstructions.
836.55 Points
Post Posted: Mon Mar 18, 2013 9:40 pm
Super easy to install the factory harness was right at each location. The only wire I had to run was the battery constant on power for the radio memory. There even wires for rear speakers.
2013 Club Funder
1,436.90 Points
Images: 20
Post Posted: Sun Mar 24, 2013 12:32 pm
Good morning Aquasport Boat Club. Hope everybody enjoyed the Gonzaga game last night. Anyway, has anyone heard of Pyle Marine Stereo Products? And better yet, anybody ever had a Pyle Stereo. I'm a big Amazon shopper and there are a lot of Pyle combo sets being sold on Amazon--Thanks
James
1,200.95 Points
Post Posted: Tue Apr 02, 2013 7:50 pm
Pyle and Boss make quite a few marine radios and speakers. I have always felt they were low quality radios, but others may differ.
Post Posted: Wed Apr 03, 2013 9:12 pm
Agreed....but they offer decent sound for a low price. Remember, it's all about the speakers!
7,686,010 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
