It is currently Sat Dec 16, 2017 3:27 am
Portal » Board index » Plumbing
Post new topic Reply to topic  [ 7 posts ]
95.00 Points
Post Posted: Fri Jun 17, 2016 12:01 am
It may have been covered but on my 2002 215DC Sport there is a well under the helm that holds water. I snaked it but cannot figure out where it goes. It must srain somewhere that may be higher than the drain since water doesnt want to flow. I have used a hose to trace all other drains and through hulls for my own educating but cannot find where this goes. Any help?
95.00 Points
Post Posted: Fri Jun 24, 2016 4:36 pm
No suggestion?
Post Posted: Fri Jun 24, 2016 10:27 pm
Is there any switches for a fish box pump out or live well on the dash?
Nothing like that on my center console can you post some pictures?
2,013,690.00 Points
Post Posted: Fri Jun 24, 2016 10:50 pm
It's possible the well is just draining into the bilge, can you fill it up then go to the back of the boat and look down in the bilge, any water should flow to the back.
95.00 Points
Post Posted: Sat Jun 25, 2016 12:18 am
Thats the weird thing, it doesnt seem to flow to bilge. I thought it might be plumbed w the livewell behind the capt seat and the drain on aide of boat is just higher than the drain in well. I am clueless. I used my shop vac and got about 10 gal of water from it and wherever it flows to.
Post Posted: Sat Jun 25, 2016 9:59 am
We don't see many Dual consoles on here. Some pics would help!
:uwp2:
Post Posted: Sun Jun 26, 2016 7:17 pm
"Well under the helm"...what kind of well? Or is it just a compartment inside the door behind the helm? Does it have a drain at the aft end? Have you tried feeding a snake into that drain? Like Bruce said, pics are REAL helpful. I know the earlier model 215 DC, but I believe yours is different...
7,565,541 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
