It is currently Fri Jan 19, 2018 9:03 pm
Post new topic Reply to topic  [ 2 posts ]
295.25 Points
Post Posted: Sat Oct 14, 2017 7:28 pm
Its been on my to do list to add a mid cleat to my 205 osprey. Is it advisable to use the powdered coated cap insert as a mounting point? ( that's where access for backing plates /washers are) This is all about keeping the boat well forward in the slip, and not really a hard strain point as there 4 other tie/off points .
10,601.80 Points
Post Posted: Mon Oct 16, 2017 8:58 am
Mount them anywhere you like. Use a quarter inch or three eighths inch aluminum backing plate and thru-bolt. Pop-up/recessed cleats are the way to go for spring lines.
7,688,693 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
