It is currently Sun Feb 18, 2018 9:33 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3
295.25 Points
Post Posted: Thu Aug 04, 2016 9:57 am
I have the same set up and some time ago found a degraded main negative cable was the cause not pushing the bendix to fully
engage the fly wheel (high pitch whine)
2012 Club Funder
2,115.80 Points
57,603.85 Points
Post Posted: Thu Aug 04, 2016 11:40 am
Well I charged both batteries all the way over the last two days, then used a jump box, which didn't make the pinon engage, and then I jumped it off my truck, it turned fast, but didn't engage. Any suggestions? Here's the wiring now from the side of the boat. Maybe you guys see something that's broken. Pictures of the flywheel are on the previous page. I still can't figure out how to really pull start it. Kind of frustrating trying to figure out why the pinon isn't engaging. All the wiring appears to be fine, so I have no idea what I'm supposed to look for.
Carl
'00 Osprey 205 w/ 200hp Ocean Pro
SEABOB4's Minion #2
Post Posted: Thu Aug 04, 2016 1:07 pm
Try calling Acme Auto & Marine Starters on Madeira beach. Also I can get you a price on a new one thru Pro Marine if you like. If the bendix is not coming out something is wrong.
Post Posted: Thu Aug 04, 2016 1:14 pm
To pull start it tie a knot in the end of a rope (nothing too fat say 3/8" max diameter). Tuck the knot into one of those triangular shaped vents (I'd pick one at around the 8:00 position) and then wrap the rope around the flywheel clockwise on top of itself say two times.... So the loose end of the rope is at about 2:00 position. Then pump the primer bulb, make sure the key is on and it's in neutral and pull on the rope in one swift contentious pull. DONT WRAP THE ROPE AROUND YOUR HAND OR WRIST! Even better tie a dowel or something on the end to make a handle.
Edit: Whoops forgot about the key.
Post Posted: Thu Aug 04, 2016 1:26 pm
Bruce left out one important instruction; turn the key to the on position then pull the rope.
2012 Club Funder
2,115.80 Points
57,603.85 Points
Post Posted: Thu Aug 04, 2016 2:04 pm
Are my wires crossed on this starter? I'm wondering if I accidentally put the output from the solenoid on the wrong post on the starter...
Carl
SEABOB4's Minion #2
Post Posted: Thu Aug 04, 2016 2:07 pm
Is this the starter you thought was going bad or the new starter?
2012 Club Funder
2,115.80 Points
57,603.85 Points
Post Posted: Thu Aug 04, 2016 2:34 pm
New one. Right now the starter is turning clockwise, lol. I think I might have inadvertently somehow put them on backward.
Carl
SEABOB4's Minion #2
Post Posted: Thu Aug 04, 2016 2:50 pm
Well since it's the new starter it's possible that the old starter was not the problem. You stated that you charged the batteries, have you load tested them?
2012 Club Funder
2,115.80 Points
57,603.85 Points
Post Posted: Thu Aug 04, 2016 3:24 pm
I have not load tested the batteries. I did use my truck to jumpstart the boat though, which I can't really imagine not having had enough power... Is the flywheel supposed to turn clockwise or counter clockwise from looking down at motor from top?
Carl
SEABOB4's Minion #2
Post Posted: Thu Aug 04, 2016 4:01 pm
Carl I think you have it wired wrong
Post Posted: Thu Aug 04, 2016 4:08 pm
Oops! Hopefully the new starter is ok.
2012 Club Funder
2,115.80 Points
57,603.85 Points
Post Posted: Tue Aug 09, 2016 1:33 pm
Yup, I forgot to update. I swapped wires the other day and it worked great. Batteries are holding a charge, so I'm really not too sure what the main issue was other then a pinion gear needing some lube, weak batteries, and the solenoid randomly going bad. I checked the charging and it's between 1.4/1.7v, so it's definitely charging them. I think the one battery is bad, and it's sucking the life out of the good one. I'm going to go scalloping Monday if the weather doesn't suck, so I'll figure out what's going on then.
Carl
SEABOB4's Minion #2
Post Posted: Wed Aug 10, 2016 12:42 pm
bring a jump pack. and make sure you dont try to start with batteries on both
Post Posted: Wed Aug 10, 2016 6:52 pm
yeah if you have a bad battery leaving it on both will drain them both down.
7,783,177 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
