It is currently Mon Feb 19, 2018 9:45 am
2016 Club Funder
819.70 Points
Post Posted: Thu Apr 14, 2016 1:30 pm
So, I couple of years ago, I installed a smaller fuel tank in my 210 Explorer, going from the 100 gallon down to about 55 gallons.
Still picking at the little things, I'm asking those of you that did similar projects, what did you do to correct the fuel gage? When my new 55 gallon tank is full, the gage reads, half full.
1992 AS 210 Explorer w '92 250 Yamaha
Post Posted: Thu Apr 14, 2016 6:02 pm
You have to change out the sender and make sure it is the correct ohms for you guage.
2016 Club Funder
819.70 Points
Post Posted: Fri Apr 15, 2016 3:19 pm
Oy...I installed the new sender that came with the tank. But I don't have any info on it. I'm guessing that I have an ohm-age issue. then. I'll have to dig into the back of the gage again. If I remember right, there's a switch back there to change the input ohms.
Post Posted: Fri Apr 15, 2016 3:23 pm
also some senders have to be adjusted so the float has full travel top to bottom of the tank.
7,784,517 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
