It is currently Wed Feb 21, 2018 3:08 am
Post new topic Reply to topic  [ 7 posts ]
3,405.35 Points
Post Posted: Wed Jun 22, 2016 8:58 pm
Any of you, ever use a 5510 with a 201 Senser cruisemaster flow scan. I pick a new one up today, still in its sealed box for $50 . I thought it was a good buy. Was it?
Post Posted: Thu Jun 23, 2016 7:28 pm
Walt, you picked up a helluva deal there! NIB, that unit went for $400+ before it was discontinued. Don't remember if the sensor came with barb fittings or not. If not, 3/8" brass barbs you can get at HD. Easy Peasy hookup, but you'll need to build a 4-wire harness for between the sender and the gauge. This is it, correct?
3,405.35 Points
Post Posted: Thu Jun 23, 2016 8:21 pm
Hey Bob thanks for the answer. I thought if anyone had used or seen one it would be you. Yep that's it. No barbs, but like you said HD. Will have them. Grabed it off criegs list. I almost passed on it, since I had not seen this unit. Thanks again. :605_thumbs_up:
Post Posted: Thu Jun 23, 2016 9:41 pm
Follow the instructions about dialing in your guage, you can get really accurate fuel burn numbers. Ask Bruce, you'll throttle off the Floscan over the tach...
Post Posted: Thu Jun 23, 2016 10:08 pm
I know I do
Post Posted: Thu Jun 23, 2016 10:38 pm
I have that same gauge. Works great. And yes it becomes your cruise setting gauge. You'd be surprised at how difference in fuel burn a small power setting change can make. The fuel flow gives a better idea of how much load your putting on your engine than the tach. The reason is the engine may be turning x rpms but it is working harder if it us burning more fuel than it normally does at a certain rpm. It was the fuel flow gauge that clued me in on what turned out to be a power pack problem.
3,405.35 Points
Post Posted: Fri Jun 24, 2016 8:43 am
Thanks Bruce for the input. Now as to which boat to put it on, learn to use it, then get another flow scan meter to put on the other. I got a feeling this will be one of the best gauges to use.
7,790,659 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
