It is currently Sun Feb 18, 2018 9:41 pm
Post new topic Reply to topic  [ 1 post ]
110.00 Points
Post Posted: Sat Aug 05, 2017 12:43 am
Hey guys,went down to the boat today to check on it and start it up. It's been about 4 weeks since I last started it. It's a 97 oceanrunner 200. It usually takes a few tries to get her going. It started and stalled. I then gave it a little throttle and when it started, it raced up past 5,000 rpms , I threw it back to neutral and it was still racing so I shut off the key. I waited a few then started it again and it did the same.
I've owned the boat about 4 years and haven't touched the cables or carbs. Took off the cover and looked at the linkage and it seemed ok. What do you think I should check? I have a factory manual somewhere, just looking for a little direction where to start. I know a few of you have these engines. Any help would be appreciated, thanks- John :)
7,783,201 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
